Sounds fun! Low rpm powaaa is what I will be lacking.
I hope to keep away from that issue with the forward facing kit
Also, Billy if you are reading this....any info on deleting the abs system?
Did you delete your abs or just relocate it? If you deleted it how did you run the lines since the abs block is used as a distribution block is it not? What about the wiring?
So you did have to make a t for the rear lines? I see it says only one output for the rear breaks and two for the front.
The brake light is activated at the MC and the parking brake. My line lock is between the MC And the PV.Awesome, and no need for the brake light connections since that is on the brake pedal assembly in the car right?
Adding a line lock to this would be done after the distribution valve or before?
