Gauge Guide
Dennis Thomas
Any good aft and boost gauge guide installs around here. Sure I can figure it out but it’ll quicker hearing from another s197 owner
EBABlacknChrome
Michigan
There were some in the diy section! Theor not crazy detailed but basic info. Getting power, where to/what to tap in differs from set to set up.
EBABlacknChrome
Michigan
I guess I should have asked what specific details you were looking for? Sbj on the passenger side foot well is where you will pull power from with a add a fuse. A/F sensor will go on driver side header at 1 or 2 o'clock. You will need a bung welded in for that. Lito told me where to place it. A firer wire is a good idea if you're going to data log for remote tuning. Boost well depending on if you are doing mechanical or electronic, I choose all electronic from Speed Hut due to options, looks, and quality. That pretty much covers everything except were you want exit the car with them. I choose the driver side foot well but there a spot behind the radio if I remember correctly. That's a good spot for A/F to exit. I am sure theres more. If you have other questions I'll try to answer the best I can depend on what you need.
Beau
