HitandRunDriver
Amateur Goon
I've been trying to figure out some gremlins on my car since I installed my JBA headers and O/R H. Initially was getting codes showing that my passenger 02 sensor was running rich, but after tune revisions and datalogging that went away and the car seemed to run fine for a while. More recently though I'm getting an intermittent P0104 code. I've already replaced the MAF sensor and ruled that out, my JLT intake tube is tightened properly and the air cleaner is positioned as far out on the tube as I can go, throttle body has also been cleaned.
On a cold start I have to press the gas pedal a bit to keep the rpm's over 1000 for the first 10 or so seconds or else the engine will start to bog and eventually die. If I let the engine die it will nearly always keep cranking but won't start until I wait like 5 minutes or keep my foot on the gas when cranking it. It will also sometimes die with the clutch pushed in like when I'm coming to, or at a stop. It fires up right away afterwards, but once it dies it will have a habit of stalling again until I leave it parked for a little while.
I pulled the plugs today just to see if there were any glaring issues with them. There's a little bit of carbon buildup but I suppose that's normal on a plug set with 40k miles. Do any of you see anything that I'm not? Drivers side plugs on the left, passengers on the right.
