Heater hose removal
popeye
I need to replace one of the heater hoses that runs to the firewall into the heater core. It's tight back there and before I spend 20 minutes wrestling with it, is there a tool to remove it or is it a squeeze and pull setup? Thanks
Wes06
Iirc you squeeze two white tabs and pull the hose.
Dob instructions recommend two people with small screwdrivers. But i accomplished alone with screwdrivers
Silverhorse.s197
Glorified Welder
Oakland, MD
I just removed mine with my 2 pointer fingers .. Push in .... Depress both tabs ... Pull out .. Took like 8 seconds max .. Not saying they all are this easy .. but mine was
