help.....
Rene06GT
low 12s for now....
Houston Tx....
My driver Window won't go up once u close the door completely, but operates normal going down. I have to hold the switch up to go up no more auto up function. Passenger side is prefect any ideas?
toorbeenee
turbine lunatic
dubai
Turn the ignition on, put the window all the way down and hold the button for 2 seconds, then put the window all the way up and hold for seconds.
it should work,,,all the best
darkhorse05
Check battery terminals, a loose one will cause this as well. Had it happen before
Pardue
Lula, GA
X2, this is the way I fixed my issue Rene06GT.
