03Glock
EX New Edge
Never heard that B4.........The thing to remember is you are not pulling timing only to make it safer, by reducing timing you are actualy allowing the car to make more power.
I actually had a long post about it earlier in this thread I believe.
close but not 100% correct.
The rule of thumb is 1-2* per 50 HP....it will all depend on the car and what is needed for that application.
I am currently pulling 8* from my base WOT timing for a 200 shot.
I'm asking this again because I want a clean cut answer.
If I take my current 91 Race tune, and pull 4* of timing from 2000-8000, I will be good to spray a 100 wet? Nothing else for the tune right? I don't absolutly have to have a nitrous tune?
without knowing more about the car it is not possible to give you a clean cut answer.
1) What is the NA timing?
2) What is the NA A/F ratio?
3) What is the nitrous A/F ratio?
4) What spark plugs are you running?
5) Do the plugs show that they are the "right" heat range?
Now for a not quite clear cut answer....if the tune-up is correct as far as heat range and air fuel ratio...start by pulling 5-6* then watch for detonation and your HP output, I would start adding timing back to the motor until you find the sweet spot.
HP output can be determined by dyno reading or drag strip trap speed. Most likely 4* from your NA tune will be OK, but I cannot insure you will not have a problem. But if you follow these guidelines I can tell you that you will have years of nitrous enjoyment.
Every car will be different, even the same car at different HP levels will like different timing retard amounts.
Learning to read spark plugs will tell you exactly what the motor wants. The plug is your "eye" into the combustion chamber. Install fresh plugs then make a WOT pull, immediately kill the engine and coast to a stop. Then pull the plugs, by looking at the ground strap will tell you heat range, the plugs base ring will tell you A/F ratio, and the porcelin will tell you if you are getting detonation/preignition.
Here is a good link for learning to read plugs....
http://members.uia.net/pkelley2/sparkplugreading.html
ive ran nitrous on my s197 ever since i got it. 75shot no tune needed.. 100shot ur gonna want a custom tune and spark plugs that are one heat range colder. ive been running 100 on it for the last 2 years, and has probably seen about 20 bottle fills. made 390whp 460rwtq through the auto tranny.. and ran 12.3 @ 118 on stock tires.
i wouldnt go over a 125 with stock fuel pumps. even with pumps, anything above 150 is risking it.
I run my 91 Bama race tune when not spraying and it is hot. I love it. Do you have his race tune?
I'm not going to be able to do a WOT and immidiatly shut the motor off.
The ZEX manual says no timing pulled for 75 shot, 2º pulled for 100 shot and 4º pulled for a 125 shot
This is assuming a stock tune...for examples sake lets assume the following
Aftermarket tune has advanced the timing 2* from the OEM setting.
To follow the ZEX guidelines you would need to run the following.
-2* for 75HP
-4* for 100HP
-6* for 125HP
This is a rough starting point to begin dialing in the correct combination between timing and fuel jetting.
For those running the ZEX kit please note that the NMU has no way of monitoring A/F to adjust the mixture. Not knocking the ZEX kits they just have, shall we say, creative marketing.
NO you can not run a race tune with timing pulled. You have to have a nitrous tune specifically made for your car. You can blow your motor up.I'm asking this again because I want a clean cut answer.
If I take my current 91 Race tune, and pull 4* of timing from 2000-8000, I will be good to spray a 100 wet? Nothing else for the tune right? I don't absolutely have to have a nitrous tune?
Nice thing about the Harris plate is it sprays full 360 degree's.
Well you need to figure on A/F which is very important. I hope you have a wideband A/F guage. STILL you need a good tune, I just would reather be safe than replacing a motor . I am only trying to help .And just why is this.....????
The only difference in my "tune"...I.E. the engine control parameters..... between a motor pass and a nitrous pass on my car is the timing retard.
