Curious as to why you stepped down from 500s to 300s?
I have noise in my heads at very low rpm. I am running 127550 with limiters.
The noise come from the left head, and the noise is like 2 or 3 lifter are badCan you describe the noise and what side it is from? Any CEL's?
Thanks, I gonna check the cam caps...Ok; I ask because after I installed my HR cams I had one of the cam caps come loose and it made a racket...my loose one was drivers side and the one closest to the front of the car.
Because I´m running with supercharger...
Then shouldn't you have went with the 127550 or 127350? The 127300, like the 127500, is for N/A.
If this is it, your experience has already helped at least 2 members here and no telling how many lurkers. Thanks for sharing.
