I like shiny :D
CanadianDrPhil
new to the game...
Burlington, Ont
DKS
Wax on, Wax off.
VA/NC LINE
Any CAI should require a tune, unless it's not really doing anything over the stock airbox, btw.
But that looks sick!!!
DKS
Wax on, Wax off.
VA/NC LINE
Yeah, those are like $200 from what I'm seeing. 18HP peak gain, I'm sort of doubting that info, lol
GrnBullitt08
Dale Jr
Northwest Indiana
Yup right around $200, and im not sure on the power gains. Im sure it flows a little better than stock and with the right tune can make some ok power gains.
Eldude
Detroit, MI
I made the mistake of buying that intake...it was 85$ at Summit Racing so I figured why not. That metal intake tube gets hot as hell, and it kept throwing CEL's even with a diablosport tune. Finally got it figured out.
On the plus side it makes lots of 'whoosh' noises if you're into that
stang2009
Elizabeth Indiana
I bought mine at PepBoys $140. It gets a lot of complements at the Shows. Some people do ask if it is a Turbo. I have had know complaints with mine, it has a 93 Octane Bama Tune. I got 27 HP Gain with the tune.
94tbird
4R70W FTMFW
NY/NJ
if anyone looks at that and says is it turbo? they fail
Eldude
Detroit, MI
Do you have the MAF insert in or did you remove it since you got a tune? I tried running mine without the insert and adjusting the tune to compensate for the increase air but kept getting CELs, so I said screw it and put the insert back in, still threw some codes but now it's settled down.
If you're running with no insert do you know how much they adjusted the airflow for this intake, or what more mainstream intake it is close to?
