rog06gt
Mash it!!!
Any news Paul?? I have a issue with cruise control in overdrive,it does not work & i have been waiting 3 weeks for a SCT tune remedy that Len is looking after.Cruise works in 3rd but not overdrive!!!
Everything is running good, except I need my car retuned. Still doesnt give any boost in 1st gear. Sometimes when I step on it in 2nd it will either give full boost or no boost until around 4500. I dont think its the converter cause it will give boost at 3k in 2nd most of the time. My MPH gauge is way off. At 70 it says Im going 35mph. Waiting on JDM for a tune. My Cruise control doesnt work in OD either. It goes on for a second, but then it goes off right away.
Guys, aren't the cruise control and the supercharger bypass valve related to load?...
Does your engine make boost in neutral...very little right?...do you think that with all that converter slippage and torque multiplication your engine sees load? very little until it finally start to stall at around 3000+ to 4500 rpm and create load...
At partial throttle you might be able to help create load on the engine...sometimes boost (partial throttle) sometimes not (full throttle)
Your speedometer error might be due to the electronic speed sensor pulse, I think you should have a 6 pulse might be a 12 on the tranny not sure, hint your indicated speed is half of actual...
I really wish somebody else you jump in and comment on this, I'm trying to learn as much as I can before doing the swap and may be somebody can chime in...I don't pretend to hold the truth...
Cheers
