Department Of Boost
Alpha Geek
- Joined
- May 26, 2010
- Posts
- 8,809
- Reaction score
- 29
are you still on the stock pump as well?
I'm running the Meziere 20GPM. Soon to be replaced with a 55GPM when I make a new IC and mod the intake.
Are you sure? I’m hearin’ ya, I’m just not 100% convinced.
Yeah, I was pretty happy with that and my dyno guy was very suprised. Like you aside from making the intake/IC better I'm pretty maxed out though.
I’m going to go from my 20GPM pump to a 55GPM but aside from that I’m about maxed out. My HE is a BeCool Pro Stock radiator that I modded to work as a HE. It’s massive, efficient and I can’t fit anything bigger in the front of the car. It works great. It’s water discharge temps are always right about ambient (my data system pulls temp from the HE exit). Aside from adding ice somewhere my water supply isn’t getting any cooler.
I will consider it (pump) for sure. I may also go to 100% distilled w/water wetter. I have an extra flex hose and new air filter I'm going to be installing next spring. Sounds like the best time to put a different pump in there. If I change the mixture then I will just have to deal with taking the bumper off in October and refilling it - unless I can find an easier way to drain the system partially and put in some antifreeze.
FWIW, My IATs are similar to the other KB cars in this thread....cruising at 70mph (2000rpm) on a 75-80 degree day they hover around 125-135 deg. A little less at slower speeds. They don't spike up too much at WOT.
I think a lot has to do with the sensor being right in the hot manifold where it gets heat soaked and stays that way. My buddies '95 GT had the IAT sensor in the manifold and always had super high IAT readings and then moved it to the pipe after the blower but before the manifold and the readings cooled way down.
My setup is a 1.7L intercooled on a '99 2v car, pullied all the way up to 14psi peak. Forged 8.9:1 shortblock, Patriot heads, custom cams, longtubes, etc. I just got the car, and as far as I know all the intercooler pieces (lines, pump, h/e, tank) are factory KB pieces.
I was a little worried too but after reading this thread it seems pretty normal. I got spoiled I guess with my old '05 GT with the On3 turbo kit (generally IATs were around 5-10* above ambient with anything other than WOT) and the intercooled T-trim I had before that on it (around 15-20* above ambient).
EDIT: side note, I'm running E85 so I'm not as concerned with highish IATs as you 91-93 octane guys might/should be.
Thanks again for the tips. That helps!
take your e85 corn gas and SHOVE IT! lol
we are all jealous lol
You should write a book.no prob. someone better benefit from my experiences lol. belts, blowers, IAT temps and now rear ends. damn, ive become an expert. that means ive spent way too much money, haha
FWIW when I did experiment with WOT pulls on the street from a roll IATs fell slightly and didn't start to climb fast until the top of the pull. Even in pretty warm temps like 80s I think it would be fine in that situation.
The issue would be after a 5-6 sec. healthy 2nd gear burnout at the race track. Going to stage I would just about bet that the temps would be right on the edge of pulling timing before you even get the green light. Admittedly I haven't tested this yet but it is my fear.
I think KB's tune and setup is overall pretty safe - especially as nice as I am to it compared to some of you guys. lol
You should write a book.![]()
