Install has begun!
It hard to say without me looking at your setup. Note, everything moves around a bit until you have all the piping from headers to y pipe on and tightend up. But yes I remember bending a few things here and there so nothing was touching or too close. those aluminum lines are very easy to bend and move.
JoshK
Modder AKA Fuel
Nebraska
Well my tuner has installed a few of these kits so maybe he will be okay with "tweeking" things a bit when i take it to him for the tune if he doesnt like the way it looks
TheToad
Oklahoma
In a different thread you said you were located in NE Oklahoma and that's where I'm located at. Which tuner are you using there? Hopefully I get to start installing my kit this weekend.
JoshK
Modder AKA Fuel
Nebraska
Just a little update
This last weekend I installed the GT500 fuel kit, my boost gauge, and changed the spark plugs. I didn't even have any of the original plugs twist off(car has 43k miles on it).
I set up an appt. today to get it tuned. Will be heading down to Omaha on the 12th to see what kind of numbers it will make!
JoshK
Modder AKA Fuel
Nebraska
Thanks guys! The things left to do to the car is to install the CMDPs, injectors, and then the 3hr trip I have to trailer the car down the tuner.
s8v4o
i am also putting on a set of CMDPs, 80lbs injectors, GT500 fuel pumps, and changing to a pmas maf. that is a lot of stuff to write a canned tune for to drive 3hrs.
Someone could write a tune to at least get you going, despite those mods. As long as you can datalog wideband AFR's and email them to a tuner he can do all the tuning remotely.
JoshK
Modder AKA Fuel
Nebraska
Well guys tomorrow is dyno day! Hopefully they can get everything dialed in in one day. Have to be at the tuners at 9:30 so will be leaving at about 6am. Just been pacing the house going over my checklist. . . .hope everything is in order!
dsmith658
Houston, TX
Good luck! Got mine on the dyno last tuesday, hope you have great results!
IIRC you are in the northeastern part of NE, correct? Where is the tuner located?
JoshK
Modder AKA Fuel
Nebraska
Yeah, I am in northeast Ne, the tuner is in Omaha, NE. It is 3hrs away. Hopefully it will get done tomorrow and I will be able to get home soon enough to load the vids and numbers up for you guys
dsmith658
Houston, TX
How long did it take to dial your car in dsmith658?
Took 3 pulls, drove it about an hour on his drive in tune. 487/488 on the dynojet. Looks like we have similar combos, except your bigger fuel system components. I used the KB BAP and 42 lb injectors and I am at about 90%.
JoshK
Modder AKA Fuel
Nebraska
Yeah, I talked to my tuner about 3 times on the phone before I decided to order everything. The concensus was to go bigger on the fuel system to handle the E85 and give a little room for growth. I was very limited on the fuel. the best gas for about 30 miles is 89oct E10 or E85. I thought it would be much safer on the E85 than the 89 E10!
dsmith658
Houston, TX
You're going to be having some fun come tomorrow afternoon!
JoshK
Modder AKA Fuel
Nebraska
I sure hope so. That 3hr drive back home should be a blast(especially since I only put 100 miles on the car from when I bought it to when I started the turbo install!) Looking forward to driving it again since it hasn't been on the road since about early Nov.(damn snow)
Sky Render
Stig's Retarded Cousin
NW of Baltimore, MD
Where the heck do you live that you can only get 89 octane?
JoshK
Modder AKA Fuel
Nebraska
numbers are in guys, stayed conservative for a little while
Mustang Dyno numbers on 6.5 psi
411hp
418ft/lbs
