Installing a paxton novi 2200.
DSargent09
Get iT!
I bought an add a fuse from auto zone. Ran the main power through the sound tube hole, across the engine bay near the top of fire wall. dropped it back down below the battery and in on the passenger side through a rubber fitting that you cut a nipple off of behind the splash shield and front tire.
The other two wires you hook up right below the gauge to the light switch and dimmer.
The vacuum line comes off the top of the BOV. I hope you ran that line ahead of time.
chon
Must install Paxton soon!
San Antonio, Texas
Thanks DSarg.
I ran the vacuum line from the BOV to the vacuum tube on driver side of intake, per Paxton instructions. Can I tap off that line or should I just run that vacuum tube directly from BOV to gauge?
chon
San Antonio, Texas
Thanks bro! Sounds easy enough. Didn't know the fuse panel was on the passenger side haha. First Mustang :)
DSargent09
Get iT!
Videos of what? Racing, or building?? I can supply some racing to suffice for a little while.
thodge
Iam doing away with my pcv system and just going to put breathers on. My ? is, on an automatic car what do you do with the 3/8 line that comes off the vacuum splitter that was tied into the pcv sytem and the intake tube?
wiplash
Cottage Grove, MN
UGH! I've got a 2200SL coming this weekend. Trying to read through this whole thread so I don't have to ask a lot of repeated questions. I'll do my best ;)
