Hot pink and green are the same spring tension. I think they went with a different company mid stride or decided to use diff paint or something later on in the spring fabrication.
Just state that you want the supercharger spring. It's rated 3 psi in the old valve, and 2 psi in the new Q valve. Same spring, just sits differently in each valve. Sounds confusing, but it's not. HOT pink, or GREEN spring, 2 OR 3 psi, and you're good.
also if your gonna put the tial on it would be easier to order it and install it initially instead of installing after everything is put together and you have to pull the fan shroud or the blower back off.
