Installing a paxton novi 2200.
onebadgsx
Houston, TX
got my t bolt clamps in, started to install. much nicer than the worm style
gizmo5
Italian between my legs
onebadgsx
Houston, TX
Have you run into any spots that make it more difficult to use those vs the junk that comes with the kit??
Just installed from tb down to bottom pipe. Everything i could do from top. I think 9 or 10. So far no. But you orient them around stuff. But it all works so far so good. Ill finish up over weekend. Just wanted to try a few out tonight
chon
Must install Paxton soon!
San Antonio, Texas
Hey onebadgsx,
Was the list you provided earlier the exact amount needed total? Where did you order?
10 for 3.25 o.d hose
4 for 3.50 o.d. hose
4 for 3.75 o.d. hose
2 for 4.25 o.d. hose
Follow you on instagram btw, the car looks good on that one pic of front of car with no bumper and the centri peaking out on top haha.
onebadgsx
Houston, TX
Hey onebadgsx,
You actually need 3 of the 4.25 o.d and 9 of the 3.25. So far thing else looks ok. Not done though.
Also not on instagram
bhowardb
YellowBlaze
Just curiosity.
With or without filter. Either way will do. It won't hurt it without, and I even advise changing the valve to a bigger one as I think the kit is undervalved from the start. They skimped on it to save money and make the kit cheaper.
I'm just wondering though, if its not important, why put the filter with it?
onebadgsx
Houston, TX
Hey onebadgsx,
I got all the clamps from race part solutions. 90 bucks for all i believe
cyclerick
Help. Out of town, Summit messed up my order for Morosso PCV bypass parts. Correct me if wrong. Need #10 hose to connect to valve cover fittings. Need 1/2" T to fit hose. Need 6 npt to 8 hose nipple fitting to connect hose to can. Need 6 npt to 10 hose nipple fittings to fit 5/8" hose to Paxton air intake nipple.
gizmo5
Because, IMO, they wanted to quiet it down. About 99% of all other valves do not have filters. From the cheapest to the most expensive. No filters. There is zero suction happening there, it's just non stop outward air. Why filter out going air?
Regardless, change it out to a bigger valve. The kit is undervalved IMO. Procharger did their kit right with the big red valve.
bhowardb
YellowBlaze
Good point. Makes sense that its 100% outgoing, so as you said, why filter outgoing air?
Is there any condensation that is coming from the discharge of the blower?
I have been looking at your setup for the Tial Q. What was said above is the Greddy style adapter works, is that correct?
onebadgsx
Houston, TX
YES....
onebadgsx
Houston, TX
post #1013 i posted a picture of mine pg 51. and before that page there was alot of info about people going with this valve. just fyi, almost everything has been discussed in this thread. i read the whole thing prior to starting my install, and re read it for my 2nd install. good info just read....
bhowardb
YellowBlaze
I have read it as well, just like to double check since it was brought up on this page again.
