Installing a paxton novi 2200.
Trousersnake
Bullet so its not even needed ?
My boss intake came with one and was not sure if it was needed
Wnt2gofst
Banned
Columbus GA
Took some pics hopefully they help
Just Another 700whp DD 5.0
Trousersnake
Is the piping supposed to be bolted in before the fan goes in?
gizmo5
Italian between my legs
1. Your flange should be towards the SC bracket, not towards the front of the car/fan. AND PUT THE BOV ON NOW! Or you will throw a wrench. I promise
2. Connect it to the coupling BEFORE you put the fan back it
3. Yeah, that fan shroud... I made it my bitch after it pissed me off one too many times... lol
onebadgsx
Houston, TX
1. make sure blower outlet is pointing straight down.
2. install pipe with blow off valve and vacuum attached now.
3. then install fan.
read back 15 or so pages gizmo shows how you may have to cut up your shroud. my first car i did but second i didnt
slvr08gt
Vilseck, Germany (Rose Barracks)
Tial Q BOV, 2 PSI spring, Greddy flange adapter, T bolt clamps, and Canton tank have been ordered.
Now only if the Paxton kit wasn't on a boat in the Pacific right now, FML LOL.
-Nick
gizmo5
-Nick
BOOYA! You're gonna love that TiAL Q...
Trousersnake
So last night I read the Instructions ... Do that ... Don't wing it looking at the pictures and watching the horsepower tv episode.. Everything I had problems with was in text..
Hope to finish it up after work tonight around 8pm when I get out of work
cyclerick
Instructions aren't clear. Are you saying to install the BOV, SC plate and SC before putting the fan shroud back in???
onebadgsx
Houston, TX
install mounting plate, install blower with outlet pointing straight down, then install first pipe with bov attached and the vacuum line attached to bov. bovwill touch mounting plate. then install fan shroud. its tight but it will go
gizmo5
This us 100% correct
Sent from your moms room...
