Andrew06GT
Hello everyone!
I have a 2006 Mustang GT Premium 5MT. For context, I'm doing some wiring re-work to remove harness connectors that are no longer needed and de-pinning anything that's irrelevant. I also have had the SRS module removed for quite a while now, as the car does not have airbags.
After disconnecting the battery, working on the interior harness, and putting everything back together my instrument cluster does not turn on at all, no gauges or anything.
The only pins I disconnected from the cluster connector were the air bag indicator control and air bag status tone control (Pin 23/24). Using a voltmeter, the 12V constant and 2x 12V ignition switched pins work to the connector ground, and the connector ground to another common ground reads below 5 Ohms. Is it possible that the cluster coincidentally went out right as I started wiring or am I missing something else that could be causing the cluster to not turn on at all?
Ford says if those pins and grounds read correctly, the instrument cluster is bad. To confirm, I check all the pins and none were pushed out, corroded or damaged. As well as, the connector was inserted correctly and seated as it should be.
I'm at a loss and anything helps right now. If it is the cluster, some advice on diagnosing the board would be appreciated as I'd like to learn.
