Is there a good way to test the diodes with a meter?I had a brand new motorcraft alternator being installed under warranty by Ford that was bad out of the box, diode issues.
Sent from my SM-G960U using Tapatalk
Yes, they should be high resistance in one direction, and almost zero ohms in the other direction. Just rvs lead to do this test. IF the piv rating of the diode is exceeded, it will blow in half..and go open circuit.Is there a good way to test the diodes with a meter?
My plan was to lay the harness out again. I ordered the workshop oem wiring diagrams for my specific model year for this purpose.Car ran and idled for about 30 minutes on initial start. Dropped e-brake to do a datalogging run and car shut off. Has not started since.
Q: This may be far-fetched but in re-reading your initial description did the car shut off immediately when you dropped the e-brake? By chance, did you run any wiring through the center console/tunnel? If so, may be worth checking if the ebrake assembly pinched/grounded/shorted/opened any wiring running through there.
After that I'd start looking closely at all wiring/harnesses you extended/moved. Go over it inch and inch looking for any cuts, scrapes, sharp bends or other insulation damage; especially where it crosses over sharp edges or through the body. Look at the solder joints/connections. Verify each connection/assignment. Ensure no wiring is swapped/incorrect; really easy to do on a build. (During my supercharger upgrade I spent most of the time on wiring. From your description sounds like you did too).
Best advice I can give you is to concentrate on the PCM issue. Trace the wiring to identify exactly which connectors/harnesses carry the sense lines and check them end to end and then check any associated circuitry. It may be beneficial to loosen up the mountings for both the BEC/PCM to see if that changes your symptoms.
Sorry to suggest this but you may find it necessary to remove any tape/plastic loom for any/all wiring you worked on to troubleshoot this one. On my supercharger build I ended up removing all of the loom/tape from quite a few of the extensions I'd made because I needed to verify I'd extended them correctly and the pin-outs. Only saving grace to all of that extra work is the car ran fine save the grounding issue I chased for two more weeks. I feel for you... Troubleshooting wiring/electrical systems is a pain and takes a ton of time. Recommend posting some pics to give us a better idea of what you've done.
Yeah, didn't have that.Some oily residue is ok. Have you checked any plugs? If it is oil, then the plugs will be soaked in OIL. But you would have had james bond smoke while it was idling if it was an oil issue.
I attempted to crank it a few times before taking stuff apart and it caught but then immediately died. Code had not come back yet.Yeah, didn't have that.
I don't understand your questionWhy 52lb injectors ?
They didnt appear to be. I installed a JLT catch can with the KB on my car.If the previous owner wasn't running a catch can you might get oily residue like that. I had a decent oil slick inside my supercharger and intake manifold before using one. It was lighter in color though.
I can do a more detailed write up after work about what has been done so far. I would greatly appreciate those scans, that manual is next on my list. I have the wiring manual attached below. I'll be in boxing my email.Good, one issue resolved.
Do you have the Powertrain Control/Emissions Diagnostics Service Manual for your model year? It's 10 pound book of troubleshooting procedures... In you don't I can send you the troubleshooting procedures for the PCM High Sense circuit fault but the scan file is too large (9 pgs) to post so pass me an email address if you want it and I'll send it to you.
If you can get one highly recommend a high end OBD/Systems/Sensor diagnostic tester for reading codes and conducting tests. It'll really help you narrow down sub-system/wiring issues faster. If you can borrow one that would be ideal.
At this point recommend being very methodical in your troubleshooting. If you can do printouts and take notes that will help you keep track of what you've tested/verified good/bad. If the PCM relay troubleshooting tests out good then start looking at everything you've done wiring wise. Check your wiring extensions and their assignments. In addition to end-to-end continuity checks are the pin assignments correct? If you've accidentally switched wiring and grounded the wrong end or something is shorted that would help explain what you're experiencing.
Another point from re-reading your initial post. Says you could not start the car after bolting down the supercharger. May be an outlier but any chance you pinched/grounded/cut any wiring when you did that?
I PM'd youI have the Workshop Manuals Vol 1,2 and the Wiring Diagrams. This one's different. Here's the manual I'm talking about; true step-by-step troubleshooting guidance... just email me for the PCM 0906 troubleshooting section.
View attachment 73829 View attachment 73830
