BMWM3
Always Online
NOTE:....
Normal driving conditions for both:
Noticed on my Saleen supercharged mustang the Airfuel ratio stays a constant 14.1 or 13.9 when cruising in 4th at a speed of 65mph .. when I throw it into neutral for getting to ready to come off of expressway to stop light the air fuel ratio jumps as high as 14.9 or 15.1 for a spilt second then at full stop and sitting at the light the air fuel ratio will hover around 14.6 to 14.7 at idle.
However on my prochargerd p1sc mustang the air fuel ratio stays around 14.4 or 13.4 when cruising on expressway at same speed same conditions... the air fuel ratio of the procharger when throwing into neutral will jump as low as 18.7 to 19.1 and read lean for a about a second or two then idle out at red light around 14.4-14.9
Is the procharger air/fuel anything I need to be worried about.
should i get a retune?
