What exactly does "hooking" on the street mean? It's subjective. Everybody hooks up eventually.
I can consistently get in the 1.6x on a well prepared track with ET street radials. That's enough to get a sore neck the next day after 10 runs. All I have is J&M LCAs and D-spec shocks. Pinion angle has never been adjusted.
On a common road surface with street tires, I'd likely struggle to get below 2.0 for 60 feet, with the same suspension. What does this tell you?
The tires, driver and road surface grip (concrete vs. asphalt) are the biggest variables IMO.
I really don't think a high powered car will ever leave "hard" on the street like you would at a track. The start of a drag strip is literally sprayed with glue (VHT Trackbite)
