ElSpa
So, after a long time everything is good and running, all parts are in place and nothing seemed to broke for 2 months
But the problem does not evade me even though I didn't wanted to accept it in the first place...
I have a 302 stroker, ported heads, turbo cams, 76mm turbo, RST bidisc clutch. The car is putting down around 600 rwhp on a Mustang dyno, so around 650+ on a Dynojet, at 14 psi.
On the rear axle a I have both upper and rear arms, carbon diff discs, all urethane bushes, 3.30" gears, and changed a number of semi or full slicks on 10.5J 18" wheels.
My street setup is only at 7 psi (the lowest I can get on my wastegate spring).
The problem is the car pretty worthless on the street since the tyres will brake loose even in 3rd gear even at half pedal...I cannot race anyone not to say that cornering is a nightmare...
What else can I do to improve traction on the street ?
I tried both full slick and semi slicks, nothing really works, unless they get pretty hot.
