Kennebell 2.6L not starting after install
teeje
Ohio
I just finished installing my kennebell 2.6l intercooled kit and I cannot get it to start. Lito sent me a base startup tune and it wants to fire but it won’t. It will sputter a little and that’s it. Lito said the fuel pressure was high. I checked for vacuum leaks with a smoke machine and found none.
does it fire at all? are you sure it's getting spark?
teeje
Ohio
Yes it fires a little bit and doesn’t run I took all of the plugs out and it’s full of fuel.
teeje
Ohio
I put the stock plugs in and it’s running fine. Sent a log to Lito..I gapped my ht0s at .035
teeje
Ohio
Put HT0s back in gss as lord at .035 and ran fine. Got my first light WOT datalog
07 Boss
Sin City
What were they gapped at before? I found gapping my brisk to .28-.30 has worked the best for me.
teeje
Ohio
The ht0s were gapped at .035. I took them out cleaned them p put them back in and it was fine
1950StangJump$
.035 for a Stage 1/2 on the 4" pulley is fine.
If you increase boost and HP, then going to .028ish would be preferred, IMO
.028 way too narrow IMHO at 7-10 lbs, I run that gap at 20#
boostedtrauma
Champaign, IL
I ran .032" at 10psi for years with a blower, and for S&Gs, I threw in HT0s gapped to .042" and still saw no sign of spark blow out in datalogs. I see no reason for going down to .028" at 7-10psi. You want as much gap as you can get and still have reliable spark. The only reason we neck down the gap is because of the increased resistance caused by the denser intake charge and our inability to increase the power to the coils to overcome the increased resistance on a stock PCM/coil setup. Our solution is to reduce the distance between the anode and cathode to reduce that resistance.
delbecque
france
I had the same problem after installing my kennebell...the furnished tuner doesn't work and I could start the engine; I had to find a competent engineer to custom modify the tuning !
07 Boss
Sin City
Well what is your fuel pressure at? If you have too much pressure it'll run rich. Have you tried pressing the pedal all the way to the floor for a couple seconds and then let off while still cranking. See if she fires for a second when you let up. If she does that means Lito is right and there is too much fuel.
07 Boss
Sin City
He has a tune from the best 3 valve tuner in the world.
