Koni Strut groan and rattle
B2B
Allen, TX
No need to completely remove the sway bar. Just disconnect the end links and tie up the sway bar and end links so they don't flop around and go for a drive.
Without going to coil overs, the two most common options are Koni and Bilstein. I used Koni DA on my Fox and Koni Yellow on my S197 without any issues, but my Suburban managed to blow out a Bilstein 4600 strut within 30K miles. No off-roading, no jumping. Just street driving.
It just to show that all brands will have defective units. The key is to buy from a reputable vendor that will go to bat for you in case anything happens. Strano, Vorshlag, etc. will do whatever they can to help you if there is a warranty claim.
jp1seattle
No they are not. I spoke to Sam Strano at length before buying the components for my suspension and koni's aren't known for putting out a bad strut. Sure it happens with that much volume in production but it isn't common. Bilstein makes excellent products and may be more geared toward performance then a entry level dampner like the STR.T but if you are looking for a good upgrade over stock and want to use a lowering spring and not spend $800 to do it the koni's are perfect. Especially if you DD the car. Yellows are a better choice and on par with some of Bilsteins offerings as well.
Sorry man....but the reality is that there have been a TON of issues with the oranges making noise. They might not have been known for making a bad strut, but they have sure been putting out a lot of noisy ones the last couple years.
01yellerCobra
San Diego, CA
This thread is making me wonder if the creak I'm hearing is the strut or strut mount now. It can only be heard at low speeds. Parking lot, driveway, etc. I figured it was the GT500 mounts we installed with the Konis.
claudermilk
SoCal
Could be the control arm bushing also. I had a similar creak and had it warrantied before doing my suspension. It sounded like it was the drivers side, they traced it to the passenger side & replaced. I still have a groan over speed bumps, but much reduced--probably BOTH arms needed replacement.
Jinx
Photography Blogger
Mebane, NC
Would a bad bushing make it sound like a box of tools being jingled everytime I go over a rutty section of road at low speeds?
If it's possible, is there a front control arm bushing kit that has better bushings like poly/delrin bushing? Seems like a cheap fix if Im replacing things
01yellerCobra
San Diego, CA
This isn't related to suspension movement. It's only there when the wheel is turned. I can sit in my driveway and turn the wheel and hear it. I'm sure is always there. I only notice it at slow speeds because there's less noise.
Jinx
Photography Blogger
Mebane, NC
No noise for me from turning my wheel while stationary.
claudermilk
SoCal
Yeah, that's not it then. The noise I was getting was a groan/creak going over speed bumps at slow parking lot speeds. Sounds like an old car that's never had the original bushings replaced. No rattling or noise just when turning--that does sound more like it's just a bad strut or strut mount/bearing.
Jinx
Photography Blogger
Mebane, NC
I removed the front sway bar (I never driven a car without one). It was mostly to see what it would feel like with a sway bar delete and eliminate that the end links were the cause. Most just wanted to see how the car felt with it gone. I'm putting it back. Lol.
But here is a video of the strut groan. No sound on compression and big groan on rebound.
BMR Tech
Traction Vendor
Tampa, FL
After watching the last two videos, I honestly think you should go through the warranty steps to get a new strut.
I am not so sure the clunking in the initial videos is directly related to the STR.T....but the noise during travel is definitely louder than what it should normally be.
I would not recommend swapping them out for the Strange Struts.
If you are going to change them out to something else, I would personally just grab some Bilsteins. As far as non-adjustable struts for these cars, I do prefer the Bilsteins over the STR.T.
Let me know if I can help in any way!
Jinx
Photography Blogger
Mebane, NC
Why not the Strange Struts?
Jinx
Photography Blogger
Mebane, NC
I don't want to spend that much on a strut that's not adjustable and I hate to reuse a strut by Koni if it gonna fail again a few miles later. What is the bad about Strange?
kona302
south texas
If they aren't preforming as they should, get them fixed by Koni. If there isn't any brake dive and it's not leaking then they will not do anything. Ive been down that route before however mine was fixed and when I got it back (after 3 week turnaround) it was still noisy. I may said this already but that's the way it is. Just save up for bilsteins.
Jinx
Photography Blogger
Mebane, NC
05gtowner
So. Cal
This seems to be an issue with 11 and up mustangs. I know there was a thread awhile ago debating whether the 11 and up crowd should go with 11 and up struts and strut mounts or do the 05-09 struts and strut mounts. Like I said I have never had a sound from mine. Nor anyone at the meets I attend who have them in the 05-09 models. It sounds like it is more of a 11-14 mustang issue. I know there were some changes albeit small to the later S197 chassis. Could this be a thing with them.?
Jinx
Photography Blogger
Mebane, NC
Never heard of this. BMR was using Strange Struts on their 2011 and Strange has 11-14 specific struts. These Steeda Mounts never gave me trouble on my old 2005 and I dont think its a problem on this 11-14 version.
jp1seattle
The Konis I had were the 05-10 ones and they were noisy. I had Bilsteins in the past, so I went back to them and haven't looked back. The feeling is night and day compared to the oranges. Definitely a more "European" feel.
I'm sure lots of people have good luck with Konis.....I just wasn't one of them.
claudermilk
SoCal
AFAIK the only changes was the thread pitch and length of the threaded section on the strut shaft. I've read numerous threads of 11-14 owners using 05-10 struts by simply using an 05-10 strut mount.
