swervo
Hey guys, coming to you all for some good advise on installing a set of LTs on my 5.0. I'll be doing it in the garage with a jack and jack stands and a few friends. Any advice would be appreciated.
well there are some places that will let me use a lift.
lifts make everything easier...
I like dropping the K member out as well.
Also be careful with the a/c line that blocks the nuts on #1 cylinder (pass front) primary tube. It will break if you try to bend it out of the way.
Oh yea one more thing, whuile the pass side header is out you might want to trim the a/c line stud that comes off of the lower frame rail. It is close to some of the headers and will cause a rattle if a primary is rubbing against it.
Good Luck!
And you can get a torque wrench in there. I don't trust GAT (good and tight)Yep, there is a nice artcl write up in one of the zines that shows them dropping the k-member for header install. 2hrs of taking k-member on and off = all the room you need to knock out the rest of the swap in about 30 mins. with ease
Thanks for the replys guys. I really didnt want to take the Kmember off, did that before on jackstands by myself on my old mach. Not really fun, but if it's the easiest I might do that.
You don't like German torque? Gudentite?![]()
