GlassTop09
Hi JC SSP,WOW I have never heard of a tuner surreptitiously disabling the Knock sensors!
What is your A/F ratio?
Well, all I can say is.......the HPTuners VCM Scanner datalog (which is reading the tune file settings out of PCM) & tune file don't lie..........so there are some tuners out there that do this kind of stuff covertly. If it weren't for the fact that I have the means to "look under the hood" so to speak, I wouldn't have known either..........
So be thus advised................they do exist.
Now as for the A\F ratio........A\F ratio at what point? I'll assume that you're referring to WOT here..........
I can't say specifically at this time as I don't have my Zeitronics Dual WB Controller installed yet to use WB's during WOT to verify the actual A\F ratio actually being applied while the knock sensors were off in my prior tuner's tune.......I DO know he used a WB to set all this while on the dyno (I personally saw the WB controller display showing 14.64 AFR......which means nothing except the WB was reading actual Lambda 1.0 at the in-tune EQ Ratio Lambda 1.0 setting using Lambda .85\.87 in OL base fuel map when EQ Ratio Lambda 1.0 equation in his tune file was using a fuel stoich AFR setting of 14.64 (which is wrong for the E10 unleaded 91oct fuel the engine was burning during all tuning......this is actually between 14.08 to 14.13 for E10) but from this info I can only deduce that the actual A\F ratio matching the calibrated WB's Lambda 1.0 reading being used was between 12.444 AFR @ .85 Lambda\ 12.736 AFR @ .87 Lambda.....(actual Lambda reading w\ correct 14.08 fuel stoich AFR for E10 fuel in EQ Ratio Lambda 1.0 equation at same 12.444 AFR is .88 Lambda\at same 12.736 AFR is .90 Lambda) which isn't bad & as long as nothing unforeseen occurred to cause this AFR to lean out any more than this (this is the Russian roulette I'm referring to) then you can potentially get away with doing stuff like shutting off knock sensors at WOT..........the problem w\ doing this kind of stuff is that this should NEVER be the TUNER'S decision\right ALONE to make w\ a CUSTOMER's vehicle w\o CUSTOMER's knowledge of, thus CUSTOMER's CONSENT......BEFORE APPLICATION of this kind of bass-ackward tuning to "band-aid" a physical component issue.......especially a SAFETY component!
So if the CUSTOMER is left in the dark & doesn't know this kind of stuff is being done w\o their knowledge\consent AND customer goes out & blows his\her engine up......say due to a simple EVAP CPV failure causing excess air entry into engine while under WOT loads........was the cause of engine blowup the EVAP CPV failure?........or the bass-ackward tuning band-aid tuner put in PCM tune file that set the engine up for failure from a simple unrelated part failure that, if the knock sensors were not by-passed AND were working properly would have potentially protected\saved engine from self-destruction.........the reason WHY they're provided on the engine in the 1st place?
The real problem now becomes an issue of he said, she said.......CUSTOMER can't PROVE any of this w\o accessing the tune file & finding the altered tuning\datalog showing the results of this altered tuning that set up this failure scenario, but TUNER CAN SAY w\ some truth that the cause was the bad EVAP CPV......but inside he\she KNOWS it was THEIR fault since THEY disabled the 1 safety device--w\o customer permission--that could've prevented this.
The question now becomes...........how HONEST will the TUNER be & eat a potential $3,000-$20,000+ engine replacement when they KNOW at this juncture that YOU the CUSTOMER can't PROVE it was THEIR doing thus THEIR fault?
So, in the end, its usually the CUSTOMER who is getting the SHAFT..........on both ends.......instead of the TUNER who SHOULD BE.
There's a whole lot more of this kind of stuff going on behind folk's backs in this industry that most aren't fully aware of...............also from folks you may be entrusting to..................
The only way I found all this out w\ my own car was from just 1 day deciding to start doing my own tuning & I got a thought much later on to reload prior tuner's tune file then datalog (just recently relocated my car's OBDII port to passenger side so I can run driving datalogs w\o OBDII interface connection interference from clutch operations) it to use to back-check some issues that I was seeing w\ my knock sensor activity thru datalogs of my own tune file's tuning to see if the issue was my tuning or the knock sensors themselves, since I couldn't find any reasoning tuning-wise on my end for what I was seeing w\ my tune file loaded so I assumed my prior tuner's tuning was done properly......even though I've found\corrected several other tuning mistakes prior this 1 in my copy of his tune file....and it was in the PCM prior my tuning start w\ no known issues concerning knock........as Paul Harvey would say......"wait until you hear the rest of the story".
In my case, just insert the word "see" for "hear". This is from a person who has been doing tuning for 25+ years & specializes in Ford tuning (he owns 2--a '07 GT & a '07 GT500 & races both regularly) .......so I trusted his expertise............nice guy to boot as well.
Now I have the recorded proof\evidence in hand to bolster all that I've typed in here...........
I just was blessed to catch yet another break from future potential catastrophic engine failure..............
My 2 cents.......................
