Lund Boost Box
Discussion in 'Mustang Chit Chat' started by JG-1, Jan 13, 2019.
  1. eighty6gt
    eighty6gt forum member
    3,024
    86
    I have a friend, built an EBO X.
    It has never ran. He has been harassing the shop to finish it for YEARS. They burned the car once due to screwing up the fuel system.
    Learn from my friend:
    a) fix it yourself
    b) find a new shop
  2. JG-1
    JG-1 forum member
    371
    22
    Ain’t that the truth!
    Well, I finally got ahold of them. Had to message them on Facebook...grrrrr. Anyway, dropping it off Friday.
  3. 07 Boss
    07 Boss forum member
    2,222
    81
    Wut?
  4. RocketcarX
    RocketcarX 95% of my weight is fuel
    2,578
    144
    He means atmospheric pressure
  5. JG-1
    JG-1 forum member
    371
    22
    Didn’t bring it to Evo. They are acting like they don’t want to be bothered. Threatening to charge me to fix the issue. Assholes.
    I did a datalog for Lund and they said everything looks good and the car is making boost. Now, I have to do a video of the Ngauge while at WOT to send to Lund.
  6. JG-1
    JG-1 forum member
    371
    22
    Question for you guys. Should I be making boost as soon as I hit the pedal? Like a medium roll from 2k to 6k rpm, should the car be making boost? Or only when at WOT?
  7. 01yellerCobra
    01yellerCobra forum member
    1,845
    50
    You'll have some boost past half throttle I want to say. I know at 3/4 throttle I see 8ish PSI out of my set up. Full throttle gives me the full 12psi. Basically once you go past 0" vacuum you should start seeing boost. Even if it's only 1 or 2 psi.
  8. JG-1
    JG-1 forum member
    371
    22
    I made a video of what I’m seeing on the gauge. In real time it doesn’t appear like the gauge is reading correctly, but if I go frame by frame I can see it reaches 12psi. So I guess it’s working correctly?
  9. JG-1
    JG-1 forum member
    371
    22
  10. eighty6gt
    3,024
    86
    hmm.
  11. JG-1
    JG-1 forum member
    371
    22
    What do you guys think?
  12. eighty6gt
    3,024
    86
    When I'm blasting along in my cruddy 3v, I see 10-11 psi for quite a while thru 3500-6500+ rpm. On a similar digital gauge.
    I believe due to that saying "analog1" there's a pressure sensor somewhere in your system and that the reading is not inferred from the fuel pressure sensor.
  13. JG-1
    JG-1 forum member
    371
    22
    And that’s what I would expect to see on mine. According to Matt Honeycutt, from Lund, who designed the boost box, the unit appears to be working as designed without issue. So idk. Seems not right to me but being told it’s right.
  14. eighty6gt
    3,024
    86
    how much are you paying lund these days? They might be hoping you just go away.
    Maybe find a lund user forum or someone else who has a "boost box" and determine if they experience the same behavior.
  15. JG-1
    JG-1 forum member
    371
    22
    Exactly.
    I’m hoping someone with experience with the nGauge/boost box combo sees this and comments.
    I am taking my car early next week to a local Mustang shop for brakes and I might ask them about it while the car is there.
  16. 01yellerCobra
    1,845
    50
    This.
    That had nothing to do with him saying to throw a cheap mechanical gauge on it.
    Did anyone else notice a trend?
  17. JG-1
    JG-1 forum member
    371
    22
    Is the mechanical gauge still warranted being the nGauge showed 12psi?
    I’d have to order one as I don’t have one.
  18. 01yellerCobra
    1,845
    50
    Honestly, I would just to make sure everything on the blower side is working as it should. If you have an Autozone or O'Reilly's by you they should have a cheap "performance" gauge on the shelf.
  19. RocketcarX
    2,578
    144
    I would install the cheap boost gauge in the same port you car using for the Boost Box, this will tell you if location is the issue with your sensor reading. If it shows 3psi then you know you need to move the sensor for the Boost Box
