M90 install
stanger1944
Are you asking for someone to take a screen shot for you?
No but thanks, I was asking if this was to turn on the pump when the key is on? If so rather than cut into the harness could I use an add a circuit in the fusebox?
Aandf1978
M90 SUPPORTER!!
Virginia Beach, VA
Yes that is to turn the pump on. Don't worry about the splicing the two wires can always be soldered back together. Don't really think taking it to the fuse box is of any real benefit.
justinsstang
Yea just follow instructions. I used the same wire in question and wondered what the hell I was cutting in half. Worked out just fine though lol.
stanger1944
Only cutting of wire I remember is this one and two for the ACT plug off of the mass air plug.
stanger1944
Ok which would give more cooling. The 2009 m90 exchanger, an exchanger from a 2011 roush or a 2014 gt500 heat exchanger
