I can't see the images, however 11.8-11.9 a/f is FI territory, not NA. That's pig rich - lean is mean....
12.9-13's is richer, I ran 13.8-13.9 afr with my 9.8:1 compression 3v na. So high 12s is decently rich for a na coyote, let alone high 11's.
I always thought that too. But these coyote motors run 11.6ish stock. Tuners don't lean them out any further than 11.9. It's been found that any leaner and there goes #8 or the like.
I thought they figured #8 out, I also thought the 13/14 5.0 motor where stronger then the 11/12, I'm I wrong?
hmmmm - I'm not familiar with that.
My .02 is try an established/reputable tuner and get your lost #'s. Lito comes to mind for a remote tuner. He's also a nice enough guy that he would probably tell you where you fucked up because it appears you have somewhere
My .02 is try an established/reputable tuner and get your lost #'s. Lito comes to mind for a remote tuner. Do you feel any difference in the cars performance ? I mean just on the street.
I'll rephrase this...
If you went to a dyno and got a stock reading and then went back a couple months later with mods and a tune and only put down 3whp more, wouldn't you be confused? Even if it was done on a 90 degree day?.
I've compared to numerous purchased tunes that I have from various tuners. All came up less than what I ended up with. All done back-to-back.
