Mastering the art of the S197 3 link suspension (sixty foot)
CandyRedGT
Illinois
I plan to try my car out this spring. Sat out all drag racing last summer due to POS trans/convertor. That is all replaced now. Soon as i figure out the funky noises in the rear...i'm hitting the track!!
NA-Stang
AMC #8 aka "The Jockey"
This may be a dumb question, but does an aftermarket adj. Panhard bar help with launching?.
Yagermeister
DFW
I have a 2011 GT Auto with minor bolt-ons. With borrowing some extremely used drag radials (2 plugs and almost no tread) with UPR UCA/LCAs, I could only get a best of a 1.93 60ft. I have now added 25hp and bought brand new rubber so I am expecting the 60ft to drop. However I am troubleshooting a different issue...Have a horrible clunk every time you touch or release the gas pedal since I installed UPR Upper and Lower Control Arms (with shims from UPR sent later as well). Had three shops take a look and reinstall them to no avail trying to rid of the clunk. I have heard that the Roush Upper uses a hard rubber bushing in the upper versus poly and that the Roush has virtually no NVH issues. Can anyone else attest to this? I am thinking of selling the UPR goods and getting the Roush Upper. Are the lowers needed to reduce wheel hop if I go only with the Upper?
Thanks for all of your help!
bigstick
Tri-Cities, MI
I've had a Roush Upper for most of the past 2 years. When I was n/a there was no wheel hop. After adding a supercharger the wheel hop returned sporadically.
Also, I noticed nothing re:NVH when it was on the car. (I just lowered mine and replaced it with an adjustable BMR upper a few weeks ago).
Yagermeister
DFW
All noise went away immediately by replacing the UPR upper and lower control arms with the Roush Upper Control Arm and the GT500 Lower Control Arms! Off to the track for testing soon
casper gt
Creighton Pa
BMR lowers
BMR relocation brackets (top hole)
4.10's
295/45r17 ET Street II's
front swaybar removed
stock suspension other than listed
stock converter
1.858 60'
Bad Intention
New Orleans
BMR Xtreme anti roll bar
UMI Poly/Roto LCA and brackets
Strange single adj. Rear shocks
Eibach pro kit springs
Circle D 3800 stall
1.51 60'
Yagermeister
DFW
GeorgeInNePA, they look similar but have a harder durometer rubber bushing. So I get a little better performance but keep the quietness ;)
Sent from my DROID RAZR using Tapatalk 2
Godzirra
Asian Idiot
Bristol, TN
Would having the panhard bar off upset the caster some? My pass side wheel sits back about 1cm toward the rear more than the driver side. The left side sticks out just a tad more than right. But then some days it's almost as if the right side sticks out a tad further but caster remains same. Also at times the car will pull hard left upon hard acceleration. But my diff is bad and I'm thinking thats just the right side pulling because that was side doing the burnout when we found out diff is bad. I have lca's from freedom racing. Non adjustable but I wouldn't think theyd be out of tolerance in length so much. Maybe time for adjustables?
08stang
Madison, Indiana
best 60 foot 2.0
- Shocks Tokico HP series
- Rear springs Steeda Sport springs
- Lower control arms Steeda
- Upper control arm Steeda non adj. for lowered cars
- posi stock
- Pan hard bar stock
- Pan hard bar support brace stock
- Gear size 3.55
- Brand/ tire size nitto 555r drag radial 285 35 18 on american msucle 18X9's
- Clutch or which converter at what stall? factory clutch 93k and counting
- Anti roll bar or which rear sway bar stock
car has near 0 weight transfer i know not what your looking for when launching actually looking at this thread to get ideas to gear the suspension more for the strip. any suggestions on what i should keep and what to scrap are more than welcome.
Mike K
WANNA BE FAST
Richfield, MN
Shocks: saleen
Springs: saleen
uca: stock
Lca's: upr rod end
panhard: upr rod end
Gears: 3.73
Clutch: stock
wheels: 20" saleen
Tires: 305/35 nitto 555r's and also 315/35
60' on 555r's 1.76, 60' on invo's 1.83
schuhanks5.0
あなたのライサー!
c.c tx
2011 mustang 6mt... stock everything suspension wise except lca relocation brackets and sway bar relocation brackets to fit the 15 in wheel. 1.51 60' leaving around 5500rpm..
schuhanks5.0
あなたのライサー!
c.c tx
LCA Relo brackets hard at work!
well they are BMR lca brackets hehe
i will ad this. after 11 passes in the bottom 1.5 60's the pinion gear and spider gears will NOT like you anymore.. time to build the diff:thud:
