silverpoison
anyone knows if someone is going 7's on a 3 link suspension ?
Did reloc bracket really raise the rear? I can't see how they affect the rear height.
Well UPR went a 1.35 60' without relo brackets.. BMR is obviously going to use their relo brackets to go the same.. Good luck BMR. I broke the passenger side in half. Matt D broke a set last year at NMRA. I'm just going to weld some 1/4" steel plates to the stock brackets. Your 1/16 isn't working.
Matt broke the bolts, not the brackets.
I don't think it's possible if installed right,and welded.
If you guys are comparing 60s with and without reloc brackets and showing the same 60, wouldn't that mean that adding the brackets drop that 1.5 even lower haha? The debate is that they are useful or that they work. Comparing 60s doesn't have a recordable way to account for driver
Just a thought.
Greg will![]()
I have the BMR brackets with no issues. Broke my diff a couple times.
Well, you have a point.
BUT...being a suspension company, why would we take a heavy car, make a TON of power...and run a HUGE tire?
To make a point, you have to prove that the suspension works...not the tires. An automatic car with a good power curve, and a huge tire = good sixty foot. Heck, even without any aftermarket suspension....as you can witness with Kelley Performance's mustang that cuts 1.3 with stock suspension on a big tire.
Here is our result from using LCA Relocation Brackets:
*Tested with nitrous on the launch, through the 330' mark
WITH: Best of 1.50 on a 265/40/18 Drag Radial, with stock 18" GT wheels.
WITHOUT: Best of 1.8X on same tire and wheel
Our car is the perfect test car. It is an auto with a tiny stall converter....and tiny tires. When using nitrous off the line, you hook or you don't.....when using an 18" Drag Radial.
There isn't really anything to debate, LCA Relocation brackets work.
GT.350-R is just one of MANY of my customers who went from spinning and inconsistent launches....to bogging, from just a LCA Relo Bracket swap. He is a true testament...or his car, that they work. He races his manual trans car in a HUGE class of automatics...and gets just about every single car out of the gate with his RT and 60' time, each and every pass.
Sharad, when we cut the same on our 2011 with a 275 tire, and less power....with Relocation Brackets, can I have a cookie?
