TW1NTRB0
Basically new in the box Magnum XL swap clutch kit from McLeod, includes the twin disk clutch assembly with 2x 26 spline clutch disks and billet steel flywheel, clutch alignment tool and instructions. I cannot find the adapter plate bolts and you'll need new Flywheel bolts. A call to McLeod will get you the bolts needed, or the hardware store. Clutch was never ran in the car but was mocked up, I misplaced the bolts. The clutch is preset and bolted together but as always verify your distance.
Clutch is rated to handle 1000lbft
$1100/ shipped Cost a lot more than that new
