MDS www.tudyno.com
Lupo222
Fort Lauderdale, FL
Congrats on the vendor spot! Not a better tuner around. Still working with me on getting mine dialed in and helping out with all my troubles!
Wicked One
westchester NY
He helped me out big time. A local shop had my car for 2 weeks for a tune, after that, I had to bring it back for a final tune, that was the last time my car ran. They blew up my new motor. Lito, with just 2 data logs was able to get the car running 200% better. Just waiting for his schedule, mine and l&m to jive so I can get a dyno tune.
Great tuner and person.
Thanks lito.
Sent from my EVO
Kidd
Berea KY
Can't believe I just saw this thread. I will definitely be hitting you up in the next few weeks Lito. Just got started back on my Turbo build tonight.
dysan
Dis-Member
Williamstown, N.J.
About to make some passes this weekend with my new engine that of course Lito tuned. Crossing my fingers for very low 10's or high 9's but no idea until I make the passes.
Redrocket06
Alvin, TX
I would like to thank you again Lito!
No matter how many dumb questions I ask or minor tweaks to the tune I asked for he helped me out. Lito even sent me a start-up tune for my new motor while he was out on vacation with his family. He knew I could have waited for the tune untill he got home and back to work, but he sent it anyways. It started right up on the first keying as if it have been started 1000 times before. The shop that is located in Houston that i originally chose to do the first start and a dyno tune would never answer the phone or emails or return my messages, all the other shops I could not place enough of my trust in to use. I chose Lito after several people here HIGHLY recomended him. Lito's customer service and knowledge has been 100% awsome!
irishpwr46
Official Site Vandal
NYC
Wow I.just saw this, ill be getting on touch after my cam install
quiksilver15
Houston
1 more lito tuned car right here. He sent me a base tune after my BBR cams and it ran awesome from the get go. Never once had any stalling or surging issues. We data logged the car and got it dialed in. I'll recommend Lito to any 3V owner.
Irishman
Ricer
West Michigan
What A/F gauge are you guys running to tune with? I don't have an output on mine so I'm looking at an innovate setup. Looking to get a remote tune from the man Lito here soon and want to make sure I have everything needed. I tried checking out the site tudyno.com but it doesn't work to see if there was a cheat sheet on things needed.
Redrocket06
Alvin, TX
I assume you mean controller, not gauge? I use Innovate LC-1. It took some time to get it working right, but in the end trial and error won out. I have the LC-1 wired to my dash mounted a/f gauge and a seperate cable wired in so I can just plug and play when I datalog without affecting the gauge. If you use the LC-1 shoot me a PM and I will help all that I can.
Irishman
Ricer
West Michigan
I appreciate that. I'm looking at the MTX-L gauge with sensor to data log with or would the LC-1 be a better option?. Looking for the easiest install with time being a factor right now.
LAStang1234
----------DSL----------
Little Rock
Took me about 30mins to hook up my LC-1 and that's because it was in the A/C vent. Extremely simple!
Redrocket06
Alvin, TX
I have no experience with MTX-L, but it also took me about 30-60 min to get the LC-1 installed to run the gauge. What took time for me was I did not spend $25 on this cable http://www.lethalperformance.com/lethal-performance-6-pin-firewire-datalogging-cable-for-x3.html, I spent $6 at Walmart for a generic 6ft firewire and cut off one of the ends and stripped the wires. The color code was what I had trouble with, that took trial and error, but ended with me saving $20.
