muztangman93
Everytime I use it with a rotary buffer or a da the reflection is so bright that it almost blinds me. Anybody else have these problems.
I have both arriving tomorrow...Menzerna PO85RD is worse![]()
Seer;Menzerna PO85RD is worse :( ;)[/QUOTE said:Can you use the po85 without the power gloss, and do you need a sealant or carnuba after the po85. My paint looks good already. I just want good protection. I just want a mild polish with something that'll lock in the shine
Sucks because I bought some M105 and M205 based on Seer's recommendations as well but I've been troubleshooting a steering problem for two weeks and haven't had a chance to use them yet.
Maybe the combo applied to your car will fix it?
I heard some people say they use both carnuba and sealant together. Would that be logical? I was thinking I would use the po85 super finish with there sealant
Menzerna Power Lock is their sealant. Yes, a lot of people will seal the surface then after it cures apply a Carnauba on top.
Reason for this is, generally carnaubas will look better than a sealant. They are typically warmer, and have a deeper, rich wet glow to them. Whereas a lot of sealants are highly reflective.
PO85RD is a finishing polish. Meaning it has fine abrasives in it used to finish up a surface after heavier polishing/compounding. It also does a good job at cleaning up minor defects, but when you use any type of polish on a vehicle's surface it strips away whatever protection that was there.
Would that finishing polishing be safe for fairly new paint. My car from the factory has extremely minor swirls
