MindIfISmoke?
Wrecking Crew
Well I finished my turbo install December 15th 2011 and I have decided I need more....
Previous setup is as fallows:
100% completely stock long block
On 3 turbo kit
67 mm snail
Frpp 39# injectors
KB BAP
This setup yeilded 494 rwhp 493 ftlbs
New componants are as fallows:
Saleen 302 Stroker
Cp pistons
Manley rods
Kellogg crank
Stock cams
Livernois phaser limiters
Tfs-15410-24 valve springs
Ram powergrip hd clutch
GT 500 fuel system
KB Dual Boost-A-Pump
SD 80lb injectors
Aromotive Fuel rails
The compression is 10.5 to 1. Before you start going nuts saying how high that is for boost. This is my dare to be great and try something new phase. I will be starting this project this weekend. Most likely friday night. Im going to have a lot and i mean a lot of questions along the way.
As of now I plan on using my stock cams... any info or advice that you guys can offer is greatly apreaciated. Also please excuse my spelling and grammer i am not an english major. As far as power goals.... i have no idea yet.... we will see what she does.
On 3 turbo kit
67 mm snail
Frpp 39# injectors
KB BAP
Saleen 302 Stroker
Cp pistons
Manley rods
Kellogg crank
Stock cams
GT 500 fuel system
SD 80lb injectors
