Born To Run
Will a Currie 9" Housing for our S197 accept Moser center section & axles from there 9" S197 setup??????????
If the axles are designed for the stock width of the rear end then yes. The 9" center sections are all the same bolt pattern from what I have found. I was told any 9" center section would bolt up in my Currie 9".
Sorry to hear about your troubles Randy. I wish I would have known sooner.Ok,thats good news.If this is possible i will be ditching this stevie wonder moser made axle housing & buy a currie one.
I have a Currie center in a Moser housing...
The only issue I had was that the Moser studs are longer than the Currie ones so the bottom bolt cut-out on the Currie center required that I trim (or replace that stud).
Going the other way you should have no issue...
