Moser/Currie
05mustang_TT_charged
Because Race Car!!
LSU Country
If the axles are designed for the stock width of the rear end then yes. The 9" center sections are all the same bolt pattern from what I have found. I was told any 9" center section would bolt up in my Currie 9".
Born To Run
Woodstock,Ontario
rearend
Ok,thats good news.If this is possible i will be ditching this stevie wonder moser made axle housing & buy a currie one.
cekim
Large Member
Earth
I have a Currie center in a Moser housing...
The only issue I had was that the Moser studs are longer than the Currie ones so the bottom bolt cut-out on the Currie center required that I trim (or replace that stud).
Going the other way you should have no issue...
Born To Run
Woodstock,Ontario
rearend
Sorry to hear about your troubles Randy. I wish I would have known sooner.
Moser said & i quote,our rearends fit & will not accept other bolt on parts,ie BMR LCA relocation brackets,panhard bar relocation brackets,without massage or tweaking,i said massage this.
Shane said they can't make the brackets exactly identical to Fords on the 8.8 as it would infringe on patent rights.That is bullshit.The company said they don't check to see if bolt on parts would fit.If they did they would realize that there is something wrong.
They did offer to buy my diff back less 15% & $150.00 gear setup fee & shipping costs!
Born To Run
Woodstock,Ontario
rearend
Good news for a change,i am calling currie today to ask some questions.
