Mt82 removal tricks?
Mustangman01
its easy.. had mine out in under 2 hours.. have to pull it again this week replace a failed spec clutch (figure that)
My mt82 is stuck in the transtunnel and I can’t remove it. I can’t push it back far enough to clear the tunnel. The bellhousing is hitting the tunnel I have a 2012 GT. It’s my daily driver and it’s stuck in my garage I’m not sure how to get the trans out without damaging the input shaft
ddd4114
Columbus, OH
I'm not sure if you already figured it out, but do you know where it's hitting on the tunnel?
I lowered the subframe by >1" at the back, loosened the motor mount nuts, and lifted the engine slightly to make it easier to move around. As long as it's angled slightly downward, it should have plenty of room.
