Ok Im getting closer and closer to my goal.
Tonight went to PBIR to test the car after getting it back from ATF from installing a shifter and loosening the converter.
1st pass on 14.5 psi street tune I just wanted to make sure everything was working correctly .
I wanted to see how much boost I can build from the time the 1st bulb on the christmas tree goes down to the green light.
Didn't build enough boost and left the line with like 7 psi's .
1.829 60ft
4.769 330
7.232 1/8th
97.07 MPH
9.401 1000 FT
11.24 1/4
121.41 MPH
I noticed that the converter did not lock until almost the end, so my mph seemed low .
I also noticed that the car felt like it wasn't making power , when I checked the data log , it showed that the computer was pulling timing , only 10* from the 1/8 on, inlet temps were 150s.
2nd pass I was lined up next to my buddy Alex'x Saleen , he too was trying a new set up , he has gone 9.20s @ 147 mph. Needless to say I was going to get rapped , but its all good. Hahahha.
I decided might as well turn the boost up , and I lowered the gate pressure on the boost controller so the boost wouldn't blow the tire out off the line.
This time I stayed on the TB a little longer , 12 psi's off the line with the 2 step set at 4100 rpms.
1.431 60ft
4.163 330
6.521 1/8th
102.91 MPH
8.597 1000 FT
10.390 1/4
121.30 MPH
This could have been the 9 sec pass Ive been working for , but I dont know what the hell was going on , the car was still pulling timing , in the back half all I saw was 6 degrees of timing . Im saying to myself , WTF!
Thats only 18.39 MPH in the back half. This car usually picks up 28 MPH on 19 psi's so on 23 psi's it should pick up at least 29 to 30 .
Something I was thinking about also is that I could here the car breaking up due to bad plugs , could that also trigger the knock sensors into thinking the car is detonateing?
Sorry for the long post just trying to figure what happened .
Pete
1.829 60ft
4.769 330
7.232 1/8th
97.07 MPH
9.401 1000 FT
11.24 1/4
121.41 MPH
1.431 60ft
4.163 330
6.521 1/8th
102.91 MPH
8.597 1000 FT
10.390 1/4
121.30 MPH
Pete
