N20 solenoid locations
05stroker
Never enough power guy!
Bullard Tx.
Is there any reason why the solenoids couldn't be mounted under a JPC intake ?
Would the engine temps be to much for the solenoids in this area ?
Also is there any reason not to run a line per cylinder in the delete plates vrs the nozzle with an s/c setup at 24 + psi ?
07stangcs
Undecided
Houston,TX
Under the intake is fine. Especially with that JPC intake sitting so high. There's nothing wrong with setting up the delete plates for direct port. PITA to change jets but you get the most bang for your buck(shot).
05stroker
Bullard Tx.
Here are some mock up pics of what I am thinking . Any concerns ?
picture.php
picture.php
07stangcs
Undecided
Houston,TX
Anything under that metal? I probably wouldn't lay them directly on it. Is it gonna be hard line or braided to match the rest?
05stroker
Bullard Tx.
It is a flat plate of .080 aluminum that would be bolted to the block . The out lines would run under the plate. Im just starting to look at ideas. I like the setup you linked better though . Really got me thinking now.
07stangcs
Undecided
Houston,TX
I looked into direct port plumbing also. It's great for someone who is set on one size shot and sticks with it. Have fun changing the jets if you go hard line. I think braided would look great in there to match the rest.
Wicked97
Beltsville, MD
Just to let you know when we had Justins Car with Nitrous we had a fogger under our intake. The purge, and everything. It works great hides everything real nice, makes for a clean Install.
jeostang
Maryland
Hey Eric, what about using a fogger on my car to help cool IAT vs the A/W cooler?
05stroker
Bullard Tx.
Thanks . I decided against the fogger and am using a nozzle setup . I did however mount the solenoids below the intake and the purge solenoid will be in the cowl. Worked real well with the mounts supplied by HSW with some modification. I will post pics this weekend.
