SoundGuyDave
This Space For Rent
- Joined
- Apr 9, 2007
- Posts
- 1,978
- Reaction score
- 29
Okay, assuming fresh rotors and pads, here's how I break them in... Go out first session, ducts sealed, take a few relatively easy laps, around 60% or so, then step it up to around 85%, until you feel the first HINT of pad fade (rock hard pedal, but reduced stopping force), then park the car, rolling it 5-6' every few minutes. After approximately 30 minutes, unseal the ducts, then go out and drive like a maniac until your brakes are shot. If it's cool out, at BHF, I would seal HALF of each duct inlet. Blackhawk is THE most brutal track that I've seen on brakes! If you have (or have access to) a pyrometer, keep shooting brake rotor temps. Most race pads have a "sweet zone" for temp where they work the best. Too cool, and you scrape off the transfer layer and can get uneven deposits. Too hot, and you get pad fade. If you suspect you're not getting enough heat in them, either left-foot-brake to drag them for and extra 100' or so before you go to your braking point, or just start braking a little earlier, and reduce your total pedal effort. All the extra friction will raise brake temps pretty dramatically. Remember that proper threshold braking will put the minimum amount of heat into the rotors!
If you're flushing, then the sequence is pretty important, to avoid cross-contamination. You flush the longest line first, and that way if you siphon any fluid from line to line, it'll be fresh... Bleeding, it's not so critical, but it's a decent habit to get into.
