Need help, steering issue
Bill6191
How's it going,
I could really use some help. I have a 2007 GT, last week I started to have some steering issues, I have no idea if its the rack and pinion, power steering pump... I need help.
Symptoms:
-No power steering when turning right, turns fine going left.
-when turning the steering wheel from right to left I hear a small single click/clunk noise.
-when steering wheel is turned to the left I get a loud hissing noise from somewhere under the hood.
Does anyone have any idea what the heck is going on?
Thanks
Boaisy
Dark Knight
Memphis, TN
Have you checked to see if the belt hops off the snake ring? If the snake ring flys free, then that would cause hissing.
BruceH
BBB Big Bore Boss 322
How's it going,
Symptoms:
Thanks
Silly question here. Have you looked under the hood? If so have you checked the fluid level for ps or have you noticed fluid all over the place? More than likely you have a punctured or otherwise compromised line/component.
gil_t2
Love Nitro in the Morning
Northern Va
I have the same problem when turning to the left only, sharp turns.... no noise and not all the time. no leaks and full of fluid.
nawagner
IA
Headers? Often times headers will rub against the steering linkage.
05sonic4.6
Central NJ
Maybe the small ujoint in the steering shaft is binding? I have fix a couple of them on the crown Vic's however it usually effects both directions
Jerrytif
Just had this issue. It's more than likely the rack. The gear box has issues and can cause the assist to not be equal or cut out all together. Even just on one side. Very dangerous in an emergency. If you replace the rack it's recommended to replace the pump too.
