Need Help With Tranny Issue
GoFaster06
Went to track yesterday. Made 4 passes, everything fine (ran Tune "A"). Before last pass (#5) I must have left intercooler on too long & battery died. Had an aquantance jump it with his truck, then went to lanes about 15 minutes later (decided to load Tune "B" for last run). Went to do normal 5 second B/O & @ 4 seconds car in other lane died, track employee motioned to stop B/O. Let off gas, released line lock, reversed car out of B/O box & stopped. After a minute they cleared car & we started up again, did a little more B/O then ran my pass. I noticed car seemed to bog around 90mph. Swapped out to street tires as usual & packed up = 1 hour. Left to go home & noticed car seemed sluggish on shifts. Swapped tunes, same issue. Trans. temp on Aeroforce seemed to be running higher than normal. Was a very cool day, lower 60's yet car seemed to be running warmer than usual. Checked all fluid levels = OK. I have a tranny dipstick, no burnt smell, level was fine. Disconnected battery & reset, reloaded tune & drove home. No improvement. Today took car out, seems to strain on shifts. Tranny temp gauge went up fairly fast even on normal driving, even on another cool day 65 degrees.
NOTE: when jumping car guy went neg. post to neg. post instead of to dead vehicle ground, car started up right away. Tune "A" & "B" I use all the time @ track/street with no issues. New 5R555 tranny in April 13', ready to change tranny fluid (suggested after 3k miles which is up)
What could have happened or be the issue?
Swarzkopf
Just kind of guessing - could you have damaged the pump or pump seal, and be experiencing fluid circulation issues now? Converter perhaps wasn't balanced correctly and the front pump seal is going? What converter and input shaft are you running?
GoFaster06
New Performance Automatic Super Streeter tranny with hardened input shaft & Circle D 3,200rpm converter installed at same time in April, 13'. Have been driving on street, 3k miles & been to track 3x (15 passes). Wouldn't the pump seal be going a lot sooner if it wasn't balanced?
Swarzkopf
Probably. LOL
Pure speculation on my part.
Hope some of the more experienced transmission folks chime in here.
GoFaster06
Update: took car to my local tranny shop. Owner went with me on a test drive. Immediately told me issue is I have "flare shifts" with tranny. Luckily Performance Automatic Super Streeter is still under 1 year warranty. Still have to pay for removal/re-install & freight to & from Performance Automatic. Also under recommendation from Circle D, I'm sending converter in for a "cut and clean" at the same time, under 1 year warranty, have to pay for freight both ways.
