I see about 4 wires that are NOT on the factory plug, but ARE on the one you replaced it with. Definitely does not look like the plug you need, but I could be wrong. Here is what I notice right away:
1) Seconnd to last column on factory harness there is no gray wire below the red. On your replacement there is.
2) On your replacement below the metal nut you will see where there are 2 red wires in the same hole, on your factory there is nothing in that hole, it is in the column before it.
3) Factory harness has a blue(black??) wire two slots below the yellow wire in the first column, replacement apprears to be none.
4) On the factory harness second column it has one red wire, while the replacement has a green wire in that column as well.
5) In the first column at towards the bottom there is a bluish gray wire that is not on the factory harness.
My guess, wrong harness!!
