I know this is not 3v 4.6 Tech related, but my crew here in Vegas really need some help on this one. So mods, even though it's not 3v tech, please let this one slide for a minute?
My buddy is very disappointed with his 2v build. I'll give all the tech info at the bottom. We think the cams are the problem, but I don't understand cam specs enough to know what's good, what's bad, and what does what. I know there's some smart people on here, I've seen them rant and rave when it comes to cam specs before, I'm really hoping they step up to the plate and explain what's going on inside my friends motor. He's $6k+ into his 2v, and the power he made is no better than stock with an off the shelf stage 2 cam. So here we go:
Block:
-Teksid .20 over
-Cobra Crank
-Manley Rods
-JE Pistons (Flat Top)
Heads:
-Stock PI Heads (Port & Polished - Bench Flowed 238 (I) 183 (E) @.600" lift
-Oversized Valves
-Manley Springs
-Compression: 12:1
Intake:
-Custom JLT CAI
-Accufab 80mm TB
-Edelbrock 90mm Plenum
-Edelbrock Victor Jr. Manifold (Port matched to heads & Polished)
Drivetrain:
-T56
-4.10 Gears
Exhaust:
-CAM Long Tube Headers 2 5/8" Primary
-Magnaflow True X O/R
-SpinTech 2 1/2" Roush Side Exhaust
Cams:
-Comp Adjustable Cam Gears
-Bullet Cams: Specs are as follows;
I'm not an engine building expert by any means. But I would think 2v ported heads would make more power than that. It kills me that I can't understand cam specs to save my life, but one thing I do understand is LSA. The more overlap you have in cams, the more air gets thrown from the intake valve back out the exhaust valve, and if I understand it correctly, it would improve the reach of your powerband, but decrease peak power made. Which is why I'm calling on the cam experts to step in and set this straight, to confirm the cams are or aren't hurting his engine from making more power.
His powerband looks great, the car feels good, but the sad fact is he's not making any more power than a stock PI motor with a set of Comp Stage 2 XFI's. The tuner fed it as much spark timing as it would take 'til it stopped making power at 310. So he's maxed out in timing with 91 octane.
If this was your 2v build, and you wanted to make the best N/A power you could with what is given, what kind of cam profile would you look for or want, and what brand/type of cam?
I'm going all out on this one, I want to get to the bottom of this. I'll be calling everyone I can to try and get this figured out, Livernois, BBR, Brenspeed, Modular Head Shop, I don't care who, I just want it explained!
Thanks for looking at this you guys!
Block:
-Teksid .20 over
-Cobra Crank
-Manley Rods
Heads:
-Oversized Valves
-Manley Springs
-Compression: 12:1
Intake:
-Custom JLT CAI
-Accufab 80mm TB
Drivetrain:
-T56
-4.10 Gears
Exhaust:
Cams:
Intake/Exhaust
Duration @ .050: 238/235
Lobe Lift: .3056/.2910
LSA: 108
Open-Close/Open-Close
Timing Events @ .050: 13-45/47.5-7.5
Duration @.006: 278/273
Gross Valve Lift: .550/.525
Valve Lash (Hot): .000/.000
Degree Intake Lobe To: 106
LSA: 108
This is directly off his cam spec card. We did degree the cams ourselves using a degree wheel and proper gauge, it's right on at 106, even confirmed the intake valve by bore-scope.
Here's his dynograph:
