New PB NA 06 Gt 12.45, thoughts w mods
Hansonb625
Set my new PB yesterday with a head wind. 2006 GT, hot rod cams, 4.10 gears, sway bar removed, delete plates, full interior, jlt series 1 cold air, sct bama can tune, lt headers, off road x, Borla axle backs, 15" skinnies up front, 28 10.5 15 et streets bias ply. Strange 12 way adjustable struts up front set full loose, strange rear shocks set at 7 clicks, cobra jet springs all around. Dumping at 5k.
Opinions welcome. Want to get this car down to 12.0s NA next year.
fdjizm
Drag Queen
Very nice runs, you can probably go a bit higher on the launch.
My best launch was 6250 off the 2 step with a 1.642, but that rarely happens anymore.
I have strange shocks all around as well, also you would do well on 26" tires.
lindertw
NoVA
nice work!
fdjizm nailed it - launch off the limiter and get 26" tires...
Hansonb625
What gear are you guys crossing the traps in, how about rpm. I am staying in third crossing the traps about 6700
lindertw
NoVA
4.10s and 26" ET streets. Launch at 6500, shift 6500-7200 (need to hook up my shift light), cross the stripe in 4th gear at 5700-5800rpm. Switching to 4.56s and that should put me at 6200-ish at the stripe.
Boss281
New Windsor, MD
I had to put 4:30s on the car and dump at 6400rpm to get into the 11s. But once there it was pretty easy after that.
