John@Lethal
- Joined
- Jul 11, 2011
- Posts
- 521
- Reaction score
- 0
New @ Lethal Performance!
Redline Tuning SN95 & S197 Quick LIft Hood Stuts!
Replace your hood's prop rod today with our Redline Tuning Hood QuickLIFT system, with patented attachment system. There are always areas that every OEM doesn't address due to cost, and our high-quality hood QuickLIFT system is one of them... Two gas-springs that lift and hold your hood without the need for a poorly placed prop-rod, simply start to lift your hood and let our QuickLIFT system take over. Your hood will lift and hold firmly at the raised position - no wind or bumping will knock it down on your head.
Redline Tuning 99-04 Mustang Quick Lift Hood Strut Kit
Redline Tuning S197 Quick Lift Hood Strut Kit (Stock Hood)
Key Benefits:
No compromise system - We design our systems from start to finish - we mount the gas springs where they need to be for proper function... our 2012 redesign is now a 'bolt-in'.
Simple one-handed operation, simply start to lift the hood and it will raise to the stock height unassisted in a smooth and controlled motion.
Progressive gas springs. Our springs are not off the shelf parts, they are designed by us and manufactured to our specifications for each vehicle application. Our exclusive end-of-force dampening slows the rate of extension over the final inches of travel eliminating stress to the hood.
QuickLIFT systems work with any hood (steel, fiberglass, SMC, carbon fiber etc.) - we design our systems using the stock hood so the main market is covered, however, our systems are made to work with 99% of aftermarket hoods. We have two versions for 2005+ Mustang - our bolt-in system which can be used on all 2005+ Mustangs that have the stock holes mid-way up the hood's frame, and the partial bolt-in made for all aftermarket hoods without the hood frame holes.
Quick and simple installation - we design the systems and write all of our own documentation. FULL COLOR manuals will arrive that will walk ANYONE through this simple installation - our customer comes first. Five minute installation can be expected for the full bolt-in systems. You do NOT need to be a mechanic or car nut like us - we are so confident in our product that we post every installation manual on our website for you to review prior to ordering.
IN STOCK AND READY TO SHIP! ORDER YOURS TODAY!
Key Benefits:
