New to the forum. 01 cobra crank in a 07 3v block?
Jason Mathews
Wanting to forge a 07 3v short block. Can i use a 01 cobra forged crankshaft and just buy a new 8 bolt flywheel? Thanks
drive_55_not
Yes ... and I have a couple 8 bolt FW's laying around collecting dust ..
A light weight ACT at <10lbs and a Heavy RAM, Roughly 28lbs ..
RED09GT
Equal Opportunity Offender
Kelowna, B.C. Canada
The cobra crank is a forged piece made by Kellogg. It is forged from 4340 steel and has center counterweight that make it a bit more stable at high RPMs.
If you are building a stock stroke motor, this is the crank to get. You would need to go into the megabuck billet crankshafts to get better than the 96-04 cobra crank in the aftermarket.
As for torque/hp limits, it is the go-to crank for 4 digit power with a stock stroke crankshaft.
