R
Ratman
Guest
This section will most likely not be needed as the GT500 has it ALL and requires no tech support!
"Don't be hatin'" (for the record - you could not get me to say that out loud if you put a gun to my head)...This section will most likely not be needed as the GT500 has it ALL and requires no tech support!
Well, I was keeping it in perspective of the GT's sack of sand and ball bearing 5-speed, rubbery driveshaft (though the GT500 shares that abomination), $random number generator shifter, scratchy window hardware, floppy hood, useless traction control, stock tires that make ice look like like a high friction surface and guages that have all the accuracy of a wet finger in the air (oh wait, I can actually get closer with the wet finger!)That and the additional 500lbs of weight on the nose and fords inability to control markup.
Other than that, there is nothing wrong with it.
INHALE....
So, given that - the GT500 is a nice starting point for mods if it were priced like the sack of upgrades that it is... It still needs "help"...
INHALE....
I'll have to get pics of my basement one of these days...I was at Evo Performance last week and they had two GT500s one had a box of take off parts the size of a coffen. They were replacing almost everything under the car. The cars were still wraped in plastic
INHALE....
Not a one...No hard feelings for Ford though, right?
I was thinking once I was done, I could line them all up like an FAA crash reconstruction...
