noisey strut mounts
one eyed willy
Pizzle fo shizzle
Lakeland FL
i can hear this clunking up front,which i assume is the strut mounts,they are stock with eibach pro kit.
will going to the gt500 mounts cure this?
$65 for the gt500 ones sounds like a fix, the steeda ones look way to expensive.
white05gt
Illinois
I have the steeda ones and still get a clunking sound if I hit a bump while turning.
SqueezeMe
I have the same setup with koni struts... The clunking is obnoxtious I heard the only ones that work were the bullit ones but who really knows...
07 Boss
Sin City
I have Pro-Kit springs and Bilstein struts with GT500 strut mounts. I have no clunking issues. I ran the springs for about 5K miles with stock struts and mounts before I got my Bilsteins. I changed my strut mounts when I installed my new struts. Now I didn't have any clunking issues before I switched either so I don't know for sure if they will resolve your issue, but I'm guessing they will.
usafimj
Tighten up the sway bar mounts and the strut tower.
5.0Shocker
Resident Bomb Tech
Guam, Island life bruh
I done the GT500 mounts 2 times. Its the bump Strut nut/ and or Sway bar endlinks. But American muscle has J&M mounts pretty cheap
tmcolegr
It's All About the Build
Central, FL
Don't be so sure the upper strut mounts are the root cause of your noise. I replaced all the upper strut mounts as per the strut mount TSB on both of my S197s and still had a noise.
Here's what finally fixed mine
  • tsb07-23-01.pdf
one eyed willy
Pizzle fo shizzle
Lakeland FL
build date on mine was april 07, how did you check yours?
jeez,i just want to fix this,lol,im tired of all the noises and rattles.
tmcolegr
Central, FL
My build dates were both prior to that referenced on the TSB. I checked mine by replacing them and it cured both my vehicles. If your build date is after that referenced in the TSB, then you probably don't have the same issue I had.
