Oh no!!!
Dave
did a big ass burnout shut the car off, sat for about half hour tried to start it and the starter just spins wtf? my wife's gonna kill me oh shit!
jdavis70
does the car try to turn over any??
jdavis70
no starter just spins pushed the clutch safety switch now it just grinds
im not sure.... possibly a bad alternator...not real sure...is it acting like a dead battery? like reseting your radio or anything like that?? ive had a problem with my alternator before and these new mustangs will not run with a bad alternator...mine went bad for some reason while i was driving first your inside lights will go off then your head light then it dies...i was able to push start it for a minute before it died again...if yours is a standard than maybe try to pop the clutch while some one pushes it and see what it does if it cranks then dies shorty after then its probably just a bad alternator....not for sure maybe try calling the ford house in your town
Dave
quite the smell as well plenty of power battery and alternator are fine i think i burned the shit out of the clutch, but come on! 9,000 miles on the car one burnout are they really that weak of a clutch?
Freaknazty
KEYBOARD NINJA
SOUTH LOUISIANA
yep you smoked the clutch and/or worse heated the flywheel so much the ring gear came off ...... ask me how I know :wtf:
smoken1986
Lynchburg, Va
Yeah maybe the ring gear..Jack it up and on the drivers side there is a rubber boot pull it out and look at the ring gear..
Real Horses
Iowa
You have a 2010? 9000 miles? You wouldn't think they would be that weak, do you?
Takes note not to do that to my car!
RRRoamer
On the bright side: If you wife kills you, at least you don't have to worry about fixing the car!!!
I would wonder how a "big ass burnout" would cause the flywheel to heat up so much. I have almost 60k on my 05 and I don't know how many burnouts I have done (mostly in first due to basically stock NA engine and 5200 feet elevation) and I have not had any clutch issues at all.
During the burnout, the clutch should NOT be slipping. If it isn't slipping, it isn't getting hot. Did you have the clutch pedal ALL THE WAY OUT, or did you still have a bit of pressure on the clutch pedal from your foot? Was it a second gear burnout (which means the clutch will have more load on it)?
Have you taken it to the dealer? Given I have seen several Ford ads showing burnouts (and donuts), that are advertising the car as suitable for that, so they shouldn't be able to deny the warranty coverage for it.
s8v4o
pushed the brke pedal to hard during the burnout?
Ding ding ding I think we have a winner. If I had to guess that's what happened. Kinda like that corvette ZO6 "burnout" someone posted where he smoked the clutch.
RRRoamer
The joys of line locks! I really need to install a set! Usually, I have the brake on ONLY hard enough so that I am still creeping forward. I wasn't doing it to protect the clutch, but the rear brakes... Maybe that DID save my clutch as well.
Dave
2008 GT/CS yeah only 9,000 miles the funny thing is it was on new asphalt that was wet what a piece of shit clutch! I do burnouts at a dead stop with the brake all the way down with my s-10 small block conversion the tranny's 30 years old and no problems no wonder people talk so much shit about fords breaking what a fuckin joke
Croft
It's GOOOOOOO Time
MD
Ummmmmmmmmm, I would call that more like "operator error". Don't blame your drunk ass malfunction on the car.
