Yes, a bluetooth OBDII connector that talks to dash command on my phone.
Hmmm wonder if I should re-check with my regular scan tool.
Your car will self destroy in any minute now.
Don't bother if you don't have a real issue, U codes are communication issues that established by Ford as "normal" unless a real issue or another code arises, you may have had these there for ages.
Gentlemen, WTF is this?
U1900
CAN Communication bus fault - Receive Error
U2011
Invalid/fault data received
They are pending but consistent, car is running normally.
SCT wont read U codes (or B or C in that matter) only P ones, good job on the BT dongle if it can read more stuff than just PCM DTCs.
I followed procedure, there is no way the margarine got near the electricals.Must be from the margarine used to crack the rods.
